Just a quick question regarding the supporting mods for upgrading camshafts on a b16a2 engine. The Skunk2 tuner series Stage 1 Cams for B16A2 seem to be a straight swap and will work with the current rev limit and springs/retainers etc.
I have read up on the cam installation process and how to set the timing once the cams are in but I am confused at that point. Once the timing is set, do I have to do anything to the ECU?
Seems a cost effective mod if it is just cams and cam gears but if I have to start chasing ecu changes it get expensive.
Want to keep the stock rev limit and valvetrain if i can. Engine has 140,000
