that was quick. to change it do i just pull it out or would i need to hold the hose underneath the manifold so it doesnt fall off while im putting in the pcv valve?
Isnt on a b16a and b18c7/1 the valve just pulls out from the top. The pipe below to the oil seperator is held inplace by a grommet -Use pliers and make sure you don't bend the rubber pipe too much as it will be brittle
its really hard coz of the hot oil makes it like plastic..anyway what i did to mine was cut it off from the bottom and change the hose. top one is easy..bottom one is a pain!!
