Results 1 to 7 of 7
    Mar 2011
    04 CL9, 11 323i
    DIY Install Catback
    Hey guys I was wondering if anyone has removed their stock exhaust and put another one in without having to go to a mechanic.
    I would rather do it myself and I've only found guides for the RSX. So would it be similar to the RSX setup?? (RSX being the DC5 Integra (correct me If I'm wrong))
    Thanks!
    Oct 2010
    '03 Euro [CL9]
    Quote Originally Posted by MingZai View Post
    Thanks!
    If you can lift the car up high enough to work on........
    It's all nuts and bolts shouldn't be too hard.. If you can lift te car up high enough safely.
    Cinderblock = death btw
    2003 CL9 5AT *ECU REFLASHED*
    Jun 2010
    Accord Euro 03
    Should just be.3 bolts connected to the cat then just rubber bushes connecting to the exhaust and can be pulled off
    I don't think you can get the exhaust out without dropping the rear shock tower (from below) and control arm if it is a 1 piece exhaust?
    Oct 2010
    '03 Euro [CL9]
    Quote Originally Posted by munkaii View Post
    Aka: got a hoist? If not go to a shop lol
    Don't need a hoist lol. I did it the other day with hand tools no problems. Undo control arm bolt, undo bottom of strut bolt and the control arm will drop with the hub, allowing you to manoeuvre the exhaust out.
    Aug 2004
    Sydney Harbour Bridge
    03 CL9 Euro
    As long as you have jackstands on all four corners, and alot of patience.
    If the car is older your more likely going to have snapped bolts.
    Isnt it just the rear swaybar in the way?
    vTeK 4-Life!
    FOR SALE: CL9
