You can DIY castor increase by simply swapping your front UPPER control arms around. (relelvant to EG/DC and EK i believe) This will increase castor , as it pitches the knuckle very slightly forward and this angle increases as the suspension turns and or compresses
interesting
is there a need to run more castor?
in a fwd... what is the pos and negs of more castor?
(+'ives)
* Increases neg camber when steering is turned (when you need it) - improving contact patch under load
* Stronger self centering
* More steering feel and feedback
* More positive /eager turn in response
(-'ives) - potential when overdone
* Steering too heavy
* Introduces bump steer because geometry is out of spec
* Puts stresses on some bushes due to out of spec geometry
* Your car becomes too much fun
Here is the same part , but from above/below .Note how it is offset - the idea is to swap either side , giving it + caster. Tiny amount , but for free its an idea.
(+'ives)
* Stronger self centering * More steering feel and feedback
You actually reduce the feedback by increasing caster angle because you overwhelm the tyre feedback with the stronger self-centering force which is simply linear with the lateral force (i.e. useless information).
