you should only adjust castor with a wheel aligner to allow you to adjust the toe correctly to suit, you need to be aware of you camber castor and toe if you want the benefit.
please don't discount using wheel alignments they are so so important i cant stress enough!!! the key is to find someone who knows what there doing and understands what everything means.....
the people using the aligners are the issue trust me!
im pretty sure that is just another design for adjusting camber. if you were to adjust castor on that arm it would be from left to right, not front to back
