Results 1 to 10 of 10
Hybrid View
    Nov 2008
    2766 NSW
    C34/RE7/ED6/FN2
    Longer Bolt Engine Stand to mount D16A8
    hi guys,
    I bought an engine stand from super cheap auto..which is the brand SCA.
    I wanted to bolt the D16 motor to it, but the Gearbox bolt to the Motor is not long enough to screw through from one side to the motor.
    I been looking for longer screws than the normal bolt with the same size, but super cheap, repco, autobarn and bunnings dont have a longer bolt the size i am after would be M12x1.25 100mm,
    because the standard gearbox bolt to the motor is M12x1.25 75mm
    can anyone help me, or you guys found a different way to put the motor to the engine stand.
    let me know guys
    cheers
    Nov 2008
    2766 NSW
    C34/RE7/ED6/FN2
    can anyone help me? or give suggestions please =)
    Apr 2009
    QLD
    ED Sedan
    this one?
    Apr 2009
    QLD
    ED Sedan
    are you talking about the bolt that is bolted through the block into the transmission?
    so there is just a hole in that part of the block, its not threaded?
    Oct 2006
    P1.5 460F/350R
    yea should be those ones mark.
    op: use engine mount bolts.
    Jul 2006
    JDM PARTS BRISBANE
    EURO LUX
    if not go to nut and bolt shop
    Apr 2009
    QLD
    ED Sedan
    just go to bunnings and get a galvanised roof truss bolt. they come in longer lengths and are cheap as shit. like a few dollars
    Nov 2009
    Gutted EF8
    Or wreckers for some large Honda suspension bolts
    Like the large long bolt for the front shock fork
    Oct 2006
    P1.5 460F/350R
    Quote Originally Posted by cotties View Post
    im pretty sure sussy bolts arent big enough for tranny hole.
    analogy: my asian penis + sasha grey's a-hole.
    Nov 2008
    2766 NSW
    C34/RE7/ED6/FN2
    thanks guys.. bought a longer bolt from an engineering place at parra.. engine is now mounted to the engine stand.. cheers guys..=)
