quick noob question will stock ek gli,ek4 and ek sedan fit ek cxi hatch ? cheers
yep, pretty much direct bolt on. brake lines should be the same
Originally Posted by danNyja1 yep, pretty much direct bolt on. brake lines should be the same CXi , came with smaller 242mm front discs (brake rotors) so no - All other EKs have larger 262mm front rotors/discs.
Originally Posted by bennjamin CXi , came with smaller 242mm front discs (brake rotors) so no - All other EKs have larger 262mm front rotors/discs. didnt know that, cheers.
