hey guys.. im assuming the answer is yes, but wanted to make sure.. would any ek dash fit ie vtir or ek9 into a CXI ek.. Even though cxi clusters Don't show revs?
yes they will fit into a cxi
so something like this would go in with no issues? http://www.ebay.com.au/itm/JDM-EK9-H...#ht_2077wt_907
yeah should work fine man
WINTON PB: 1:36.30 WAKEFIELD PB: 1:07.59Supported by: Hybrid Racing + Hardrace Australia MSC Performance FTW
Originally Posted by DNYALL yeah should work fine man yeahh you'd think so. gonna do bit by but.. looking at an ek on wednesday. hopefully its in good nic!
Will fit straight plug and play! Only thing which doesnt work is the dimmer. Hope that helps you
Originally Posted by LD_Mart Will fit straight plug and play! Only thing which doesnt work is the dimmer. Hope that helps you yeah man cheers!! so what if its too dull! haha
its not too dull, from memory the clock is sometimes to dull during the day if u have ur lights on. otherwise its fine
ohh ok.. so you will be able to see the cluster at night?
Had this installed on my ek, cluster's up for sale if you're interested, I'm in brissy too. Yeah at night time you can see fine no problems
