Few Supercharging Questions for my B18CR
i have just purchased a JRSC for my JDM ITR.
i have a few questions,
basically i will be installing it myself (prepare yourself for head torments as i can never work shit out )
the things im worried about is that after its all installed and everything is running, will it be safe for me to drive it from my hometown to sydney (bout 6 hours away) without it being retuned is currently N/A tuned and is about 135KW
what about injectors?? will my standard ones be able to cope?
can i still use my INJEN intake??
are there any other problems i may run into?
jdmEG5: Will u take 2 ounces of weed +$500 your way? I'm not kidding.
Speed is a matter of money... How fast can you AFFORD to go?
What PSI belt are you going to run?
Don't think your ITR injectors will cope, and even if they did they'd be working very hard. Best consider something like a 440cc injector so they won't have to run at maximum capacity. What are ITR ones, 240cc?
Don't know a lot about the SC tuning but given the distance it might be a good idea to take it on a trailor. Personally I would, that's a long drive bro.
Injen you should be able to use, at least most of it should it require any modifying.
Problems...I'm sure you'll have lots mate haha. Will be interested to see though
will be on a 5psi to start with, i am completely and entirely new to Superchargers... honestly never thought id own one lol.
will the car be alright to drive without being tuned?? or will it detonate?
in the kit there is a walbro fuel pump, and also a fuel pressure regulator.
hahaha im sure ill have gazillions of problems glad you guys are all here to help
im hoping people will be interested in seeing my progress on this, as i dont think there are a great deal of S/C b18cr's?
Truthfully, u can drive without a tune, but its very risky, and with a supercharge, u have more of chance of detonating the motor than turbo, as turbo u can drive off boost safely, were supercharger, its always creating positive manifold pressure, the risk are much higher imo
If i recall, the JRSC kits often use a twin screw type sc, usually a JRSC housing with eaton internals, so if it does fail, atleast u know it can be rebuilt here lol
Definite go for anything from 330cc on wards, but really depends on the power ur after, which will determinate what injectors u get, 440cc is the norm, even ppl with 120kw still run 440cc in there car
at the end of the day, just ask the tuner what can be done or not, cause its them who will make or break ur motor, not us LOL
TODA Performance Australia Pty Ltd
TODA Racing - FIGHTEX - MFactory - HALTECH - EXEDY
Race engines, Dyno tuning, Licenced workshop, Parts.
P:0401869524 email: toda@todaracing.com.au
Mate
Do this - grab all the parts , and drive to Sydney and get it installed here - preferably at the tuners shop and not worry.
Ps don't use standard injectors.
WOW thanks for that adrian!
Ben: well at the moment, i will be probably be installing it at home, injectors i will have to replace here also (if necessary), my main concern is if i bump up the fuel pressure to x? amount will it be safe for me to baby it up to adrian (toda).
reguarding injectors, someone explain to me why a fuel pressure reg is provided with a JRSC, is this for cheapskates who wont buy new injectors? or can i actually use this safely with my injectors? or at least until i can afford good ones that meet my requirements.
Originally Posted by bennjamin
Mate
Good advice. You might save a few hundreds doing it yourself, but might end up losing a few thousands to save those few hundreds
If it was me...
Bolt it all up...
Get it running...and just take the supercharger belt off and cruze to sydney...
Put da belt on and get it tuned. ...
Install the complete kit but not the belt that run the supercharger. You should have no problems. Getting it to where ever your taking it. Cos with out the drive belt you won't make boost. I sometimes run my system like this on long trips to save a bit of fuel.
touge is my style, F@CK your style!
Originally Posted by IEVAQ8
If it was me...
Bolt it all up...
you got in before I could finish posting. Same point!
just to ask, but wouldnt your economy be the same if not worse due to such a restrictive path the air has to flow through?
