Results 1 to 12 of 12
Thread: cbr blinkers
    Newcomer Array
    Feb 2009
    Sydney
    Type R
    cbr blinkers
    my indicators blink real fast when indicating right but when indicating left its normal. what could be wrong the blinkers are standard ones and not aftermarket. i got a 1990 model cbr250rr
    cheers
    Newcomer Array
    Sep 2007
    West Sydney
    del sol
    i had the same problem when i first got my cbr. one of the wires on the blinkers are not pluged in properly. plug them in and should be fine
    Newcomer Array
    Feb 2009
    Sydney
    Type R
    ok thanks will try tomrrow morning
    Dec 2009
    smashed crx =]
    lol cbrs r so common for blinker issues
    Aug 2008
    Sydney
    Honda Jazz R
    both sides on mine blink fast but i dont have any blown bulbs, they're prob the wrong wattage
    ...ZzzzZzzz Array
    Aug 2005
    Pushbike...
    All four indicators working?
    FFFFffffuuuuuuux999
    Oct 2009
    hehe
    hehe
    Quote Originally Posted by najdi View Post
    i had blinker problems to lmao.
    this guy must be right.
  8. #8
    Mar 2005
    Sydney
    94 CD5 04 600RR
    Quote Originally Posted by EG52NV View Post
    you sure you aint running leds?
    Albert Einstein Two things are infinite: the universe & human stupidity; I'm not sure about the universe.
    Put your location in your profile, makes referring help easier!
  9. #9
    Aug 2008
    Sydney
    Honda Jazz R
    Quote Originally Posted by ICACHA View Post
    It's the stock blinker assembly lol
    ALLIGATORS GOT A GATE
  10. #10
    Sep 2005
    BNE
    b&w eh, blurple ek
    I had a similar issue when i installed some aftermarket indicators on my CBR. They weren't LED's, just normal T10 wedge that almost every Honda uses in their guard indicators, and yeah they draw less current than the bulbs that were in there. Ended up having to install a new relay to fix the problem
    Life is like a box of chocolates
    It doesn't last as long for fat people
  11. #11
    Feb 2012
    Wollongong
    EP3 Type R
    Which CBR do you have?
    I had the same trouble with my 06 CBR1000RR. All of mine are LEDs so bit obvious why.
    Installed an aftermarket flasher relay which fixed the problem. Plugged straight in and just needed to be cable tied in place.
    Think they are designed to flash at the same rate regardless of circuit resistance and stuff like that.
    Might be a good $20-30 investment.
    It was called a Motrax flash-it relay
  12. #12
    Apr 2005
    At home
    EG5 > CL9 > RE4
    Mine has not giving me any problem, even after i change to aftermarket led's, but with relay for sure..
