as said by everyone else make sure you get hubcentric spacers, go with H&R, made in Germany and good quality. i run 15mm H&R with no problems. Depending on what size you end up getting you may need to install extended wheel studs, if you buy h&r they come with the spacers.
15 mm seems too much with 8mm it sticks out a tiny bit already just need spacers to stop scraping the inner guard with full car or hard corners also need some lowering
