SUPERIOR STOPPING FOR PERFROMANCE DRIVERS
Bendix Street Road Track brake pads are unlike any other on the road. They have been engineered with advanced technology originally created for European racetracks. And now it is available for the street and road; high performance brake pads for high performance driving.
Street Road Track has been developed by one of the world’s leading high performance friction material manufacturers incorporating the latest race technology and extensively tested under extreme conditions. The rear of the pad also features a gasket, for reduced noise and increased heat resistance.
Street Road Track delivers excellence in braking, in both professional and road applications. These brakes are the standard choice for highly skilled drivers who command absolute control of their vehicle. To ensure reliability at every corner, these pads have been comprehensively tested by leading friction engineers to create a pad designed to handle a variety of applications – street, road and track. Bendix Street Road Track has been rigorously assessed against other leading brake pad brands to deliver superior control and consistent braking from the first stop to the last.
The professional standard in braking
Bendix Street Road Track brake pads have been engineered with advanced technology originally created for European racetracks. And now it is available for the street and
road; because you demand high performance brake pads for your high performance driving. Street Road Track has been developed by one of the world’s leading high
for reduced noise and increased heat resistance. Street Road Track delivers excellence in braking, in both professional and road applications.
Street
CONTINUOUS HARD BRAKING WITH LOW FADE
Ordinary brakes heat up after a few hard stops and the friction level typically takes a dive (fade) meaning you have to push harder to engage the brakes. As you see in the graph, Bendix Street Road Track Maintain their friction level even as the temperature rises with continuous stops, for the same pedal effort.
Road
FRICTION LEVEL MAINTAINS OPTIMAL RELIABILITY
Street Road Track was tested against two leading competitors by applying the brakes in ‘snubs’* that reduce the speed by 40km/h from the starting speed and measuring the speed and pressure sensitivity. As the graph demonstrates, Street Road Track delivers outstanding friction stability for complete control on the road.
* A snub is a brake application that doesn’t completely stop the car.
Track
STABLE FRICTION THROUGHOUT THE STOP AT ALL TEMPERATURES
Stability for brake race materials is paramount for optimal brake balance. If the rears step up in friction and the fronts fade off, a hard brake will lockup the rears and spin the vehicle into a sandpit. So we put Street Road Track through its paces on race tracks and one of the world’s most challenging simulation tracks. The graph shows the temperature range as the brakes are applied into Turn 1, slowing from 195km/h to 95km/m creating a “g-force” of 0.75g which is close to lock-up. This process was repeated for 10 simulated laps. The result shows extremely stable and reliable performance compared to other leading competitors.
For more information on Bendix SRT brake pads or to see the full range of brake pads Bendix has to offer please Click Here
