Results 1 to 12 of 23
    Jan 2011
    Port Macquarie
    I own an Engine
    H22A Manual Tensioner
    Hey guys,
    My belts are starting to show some wear due for replacing soon.
    I've found a kit that will get rid of the auto tensioner on H22's and replace it with the manual system on H23's.
    Would anyone recommend doing this? I have had the auto one go out on me on my old prelude but my belts didn't slip or anything.
    Also has anyone else done it? Do you have to mod anything or do all the parts bolt in?
    This is the kit
    http://www.importrp.com/product.php?productid=41997
    Aug 2007
    DC
    i would say do it, i had it before on my H22, using the H23's manual tensioner best to use OEM.
    Coup De Grace
    A.K.A VTI60Y Array
    Jan 2004
    8100rpm
    RUSTED Sleeper
    I have this exact kit .
    Best thing you can do,
    Also check out balancer shaft removal.
    KK24AA
    Jan 2011
    Port Macquarie
    I own an Engine
    Was it easy to install? Don't have to cut/drill or anything like that?
    A.K.A VTI60Y Array
    Jan 2004
    8100rpm
    RUSTED Sleeper
    Just google it.
    Very easy to do tensioner.
    Balancer is a little more involved
    KK24AA
    A.K.A VTI60Y Array
    Jan 2004
    8100rpm
    RUSTED Sleeper
    But you can run no balancer belt,
    You will get a Lil more vibration but a Lil more power.
    KK24AA
    Jan 2011
    Port Macquarie
    I own an Engine
    Yeah just read into it, is it really noticable? I mean I can remove the belt easy enough but is it worth it to actually remove them altogether?
    ignore the balance shaft belt removal idea.. if that guy above you trying to make you confuse coz it's not necessary
    A.K.A VTI60Y Array
    Jan 2004
    8100rpm
    RUSTED Sleeper
    Quote Originally Posted by shepparton View Post
    Why ignore it for?
    What's the problem with it?
    I added that as a suggestion.
    It's been done by many built h22a where shafts are completly removed and dowels are used, and on more standard sort of motors the belt have been removed with proven results even on a stock motor.
    KK24AA
    A.K.A VTI60Y Array
    Jan 2004
    8100rpm
    RUSTED Sleeper
    Quote Originally Posted by Wru View Post
    Look removing the belt is easy.
    Like turning something that like a power steering pump.
    If you want to go the whole way well it's time for dowels, block off plates etc etc,
    Bismoto sell a real good kit.
    Used it on my engine with great results.
    But I have noticed a bit more vibration at high rmp.
    But I guess if u want power well it's a sacrifice u Goto take.
    KK24AA
    Jan 2011
    Port Macquarie
    I own an Engine
    Yeah I don't care for comfort or ride quality or any gay shit like that, I already took out the air con, and power steering.
    Sometime next year I'll be building my engine, I'll look into completely removing the shafts when that gets done, don't want to tinker too much on the engine right now, I want to get most of 'proper' engine work i.e other then bolt on mods/removing simple shit etc all in one hit.
    I'll definitely get the manual tensioner kit right now however.
    A.K.A VTI60Y Array
    Jan 2004
    8100rpm
    RUSTED Sleeper
    Yeh I recommend that.
    I have some h22a parts performance ones of you interested . Pm me if you want
    KK24AA
