FINE GRADE CAR DETAILING CLAY BAR 100G
A clay bar is an essential car detailing tool required to remove many things such as:
- Surface contamination on the surface of your paint
- Tough bug tar/asphalt/general stains acquired from a long period of driving
- Water stains
- Stubborn stains which normal washing wouldn't remove and so on
Not only does it remove harmful contaminants, it also leaves a glass smooth finish without using heavy chemicals.
Usage/Directions:
For best results, it is best to wash your car to remove any dirt on the surface of the vehicle to prevent scratching when using this product.
Using water as a lubricant will suffice, but it is recommended to use soapy water whilst using the clay bar.
Please make sure to mould the clay over after using it on different areas of the car so you are always using a fresh layer/mould which hasn't been rubbed.
This excellent car detailing tool can be had at a affordable price which will be enough to clay your car 5 times over (car detailing experts recommend to clay your car at least every 3 months) so this bar will be enough to use over the whole year as long as it is properly maintained and sealed after use.
WARNING: MAKE SURE NOT TO DROP THE CLAY BAR ON THE GROUND AS CONTAMINANTS WILL BE LODGED INTO THE CLAY CAUSING SCRATCHES OVER YOUR PAINT IF IT IS USED AFTER DROPPED.
Price:
1 Claybar - $16
Claybar clearance sale!
10 clay bars for $35 + postage. Tell your friends and grab a bargain!
Postage: $13.50 for 10 clay bars, then $5 for every extra 10. Postage is EXPRESS postage. If you order before 6PM Mon - Thu, you will receive it the next day if your postcode is within the express next day guarantee range.
