Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958
MFACTORY METAL LSDs
Results 1 to 7 of 7
    MFACTORY METAL LSDs
    MFACTORY METAL LSDs
    Now Available for Immediate delivery
    Experience the MFactory Advantage
    Gain the advantage at the track
    Please note: MFactory is a manufacturer and supplier of gear components for other brands. However, we constantly update our gear designs with our inhouse engineering team which other are not privy to. For the Latest and the Best, don't settle for anything less than Original MFactory Racing Components.
    MFactory is also the official transmission supplier for all Honda of America's production-based race cars.
    MFactory vs .....
    MFACTORY METAL LSDs
    Through the smooth and constant distribution of power to the wheels, the MFactory Metal Plate LSD puts the power-to-the-ground and maximises your vehicle's traction where conventional Torsen LSD's fail.
    Available in 1.0 way (Acceleration Only), 1.5 way (Acceleration/Deceleration) and 2.0 way (Acceleration/Deceleration). All MFactory Metal Plate LSD's are set at 60% Lock for Street/Track usage.
    • Made from imported Japanese Steel
    • Forged and Cryo-Tempered for unsurpassed toughness
    • Advanced Shot Peening technology increases surface hardness
    • Only the highest quality Brighton-Best Hardware is used
    • Coil Spring preload system ensures minimal powerloss and maximum response
    • Lower initial pressure ensures maximum durability and chatter-free operation
    • Fully rebuildable with adjustable lock (60-100%) and option of different cam type
    • The 1.0 way cam type provides the option to adjust for 2 distinct levels of initial torque transfer
    FITMENT
    • Honda B16A (Cable/Hydro) Metal Plate LSD - 1.0 Way
    • Honda B16A (Cable/Hydro) Metal Plate LSD - 1.0/1.5 Way
    • Honda B16A (Cable/Hydro) Metal Plate LSD - 1.5/2.0 Way
    • Honda B16B/18C Metal Plate LSD - 1.0 Way
    • Honda B16B/18C Metal Plate LSD - 1.0/1.5 Way
    • Honda B16B/18C Metal Plate LSD - 1.5/2.0 Way
    • Honda D-Series Metal Plate LSD - 1.0 Way
    • Honda D-Series Metal Plate LSD - 1.0/1.5 Way
    • Honda D-Series Metal Plate LSD - 1.5/2.0 Way
    • Honda H-Series Metal Plate LSD - 1.0 Way
    • Honda H-Series Metal Plate LSD - 1.0/1.5 Way
    • Honda H-Series Metal Plate LSD - 1.5/2.0 Way
    • Honda K-Series Metal Plate LSD - 1.0 Way
    • Honda K-Series Metal Plate LSD - 1.0/1.5 Way
    • Honda K-Series Metal Plate LSD - 1.5/2.0 Way
    • Honda Civic R16A/18A Metal Plate LSD - 1.0 Way
    • Honda Civic R16A/18A Metal Plate LSD - 1.0/1.5 Way
    • Honda Civic R16A/18A Metal Plate LSD - 1.5/2.0 Way
    • Honda CR-Z Metal Plate LSD - 1.0 Way
    • Honda CR-Z Metal Plate LSD - 1.0/1.5 Way
    • Honda CR-Z Metal Plate LSD - 1.5/2.0 Way
    • Honda S2000 Metal Plate LSD - 1.0 Way
    • Honda S2000 Metal Plate LSD - 1.0/1.5 Way
    • Honda S2000 Metal Plate LSD - 1.5/2.0 Way
    • Ford Focus MTX-75 Metal Plate LSD - 1.0 Way
    • Ford Focus MTX-75 Metal Plate LSD - 1.0/1.5 Way
    • Ford Focus MTX-75 Metal Plate LSD - 1.5/2.0 Way
    • Nissan Silvia S14a Metal Plate LSD - 1.0 Way
    • Nissan Silvia S14a Metal Plate LSD - 1.0/1.5 Way
    • Nissan Silvia S14a Metal Plate LSD - 1.5/2.0 Way
    • Toyota MR2/Celica S-Series Metal Plate LSD - 1.0 Way
    • Toyota MR2/Celica S-Series Metal Plate LSD - 1.0/1.5 Way
    • Toyota MR2/Celica S-Series Metal Plate LSD - 1.5/2.0 Way
    • 1.0 Way Replacement Cam (Dual Torque Settings)
    • 1.0/1.5 Way Replacement Cam
    • 1.5/2.0 Way Replacement Cam
    • Replacement Forged Plates
    PM or Email for current pricing
    Beware of MFactory copies in the market
    Buy only original MFactory products from an Authorised Dealer or risk getting inferior quality products.
    MFactory Competition Products
    Learn more about MFactory LSDs here
    Nov 2004
    NSW
    EG6ish
    Could you please explain the diffrences in maintenence life expectancy between the metal and helical?
    Ctrl + W
    Nov 2004
    NSW
    EG6ish
    I understand the diffrences, but having never owned a vehicle with a Clutch type LSD, i do not know how long theyre expected to last (even rought idea, 20,000ks 50,000, 100,000??). Also it mention 'more maintenence,' but what is this extra maintenance and when do u do it? Is it only the fact your meant to use specific oils?? How much does it cost etc to maintain if there is more than just this?
    Ctrl + W
    How often it requires servicing depends on the way you drive your car. For a Race Car, we advise that the LSD is inspected after every season.
    We also recommend changing fluids every 2~3 events.
    For a street car with the occasional track day, a transmission oil change everytime you change your engine oil is recommended.
    As for specialty oils, its not really necessary - there's a thread on that in my posts, you can read up on that.
    Hope that helps.
    Hi All,
    To celebrate our NEW Site, ALL HONDA LSD's will come with FREE NEW DIFF Bearings from now till the end of the year!
    PM me to place your order.
    http://www.teammfactory.com
