Page 1 of 4 1234 LastLast
Results 1 to 12 of 40
    Jun 2010
    basement carpark atlantic ocean
    1995 Civic Ek1
    MINI-ME SWAP! y4 swapped with y8
    This is to be used only as a guide. I or Ozhonda will not be liable for any damages/faults etc that could potentially result from this DIY. Please be careful, make sure to have good quality tools and keep yourself safe at all times.
    Hey guys, I have successfully conducted a mini-me swap on a d16y4 gli. I was having doubts about this, but I went through with the idea anyway. First off, would like to thank my friends for helping me. There are 7 of them! you know who you are!
    For all of you who want to feel vtec on a non-vtec car.. yes, you are able to experience it!
    Item's that you'll need:
    - y8 vtec head (mine didn't come with the camshaft oil seal, vtec solenoid)
    - y8 head gasket, y8 exhaust gasket, y8 intake gasket, valve cover gasket, camshaft oil seal, spark plug gaskets
    - VAFC2 controller/ any vtec rpm switch - much preferable if you have the VAFC controller
    - d16y8 spark plugs
    - new y8 timing belt (may consider getting one if it has been a long time since your change)
    - vtec solenoid
    - copper spray
    - gasket sealant
    - wide array of tools ranging from breaker bars, torque wrench, socket wrench, screw drivers, etc etc. Make sure you have the appropriate tools and the work space for it. It can get really messy.
    Original parts that will work with the new head: y4 distributor, y4 spark plug leads, intake manifold, exhaust manifold, y4 cam gear, valve cover.
    Do as much research as you can before starting! I never needed to ask for help on this topic except on wiring the vafc2 controller to the car's "black sheep ecu".
    Attachment 20263
    Step 1: loosen left tire bolts. Jack up car and put it on jack stands.
    Step 2: Remove left tire.
    Step 3: remove splash guard underneath car (this is to stop coolant/oil from spilling everywhere).
    step 4: drain coolant/engine oil. Wait for the fluids to drain out completely. (You have to keep in mind that when you take your y4 head off, it will still have some collection of oil that didn't get drained. As you take it out, it will mix with the collection of coolant that didn't get drained too in the cylinder sleeves).
    Step 5: remove your intake pipe, spark plug leads from the valve cover and distributor, and place them to a side. Do not remove the leads from the distributor!
    Attachment 20275
    Step 6: Unbolt your valve cover screws and take the valve cover off. Some may be hard to come off, so just knock it a few times. (it is very important that nothing gets dropped into the cylinder head before or after the swap!) Remove the necessary covers just beside the cam gear needed for removing the head.
    Attachment 20259
    step 7: You should be able to see your cam gear and the valves. Now, you need to place your cam gear in top dead centre before removing the head. VERY IMPORTANT. Turn the crank bolt located in the left wheel well until the up on the cam gear is facing 12 o'clock.
    Attachment 20266
    Step 8: Unbolt the screws that are attached to your fuel rail. They are the ones that are mounting your fuel rail on the the intake manifold. Be sure to gently remove the fuel rail as the fuel injectors that are attached to it are fragile.
    Attachment 20260
    Step 9: Now unbolt your exhaust heat shield and exhaust manifold. There is a sequence to follow. Get your Honda manual or a helms manual. I used a Honda manual
    Attachment 20262
    Step 10: Do the same with the intake manifold. There is a sequence to follow too.
    NOTE: We were only able to remove the exhaust manifold by removing the bolts that join the manifold to the down pipe so that we had some leverage to it slide out.
    Step 11: We had to unbolt the power steering mount bracket so that the old head was completely free for removal.
    Step 12: Remove the radiator hose connecting to the cylinder head. We had to unbolt the coolant funnel and reuse it on the new head as it didn't come with one.
    Step 13: unbolt your headstuds. There is a sequence to follow.
    Step 14: Remove your cylinder head. There are 2 small hollow cylinder shaped pins that will be removed as well. Be sure to keep track of them in case they fall out just as you are pulling the head off. (at this point, a whole heap of oil may spill and mix with the left over coolant. So just be mindful of this and be sure to flush your coolant after the swap). Take the gasket off and put it somewhere.
    Step 15: clean your pistons and make sure to clean the surface to where your new head will be mounted on.
    Attachment 20273
    Step 16: Replace the gaskets on all the parts listed and just put them all back. Be mindful of the torque specs and sequence needed when bolting the bolts back up.
    Attachment 20259
    (if applicable) Step 17: Bolt the vtec solenoid to the back of the cylinder head. There is a port specifically suited for it. It uses 6 x 45 flange bolts. Torque it up!
    Complete! you successfully have just completed an engine head swap! but wait!! now you need to wire your VAFC2 controller to your ecu.
    Attachment 20276
    Here are a few guides on how to wire them up:
    1. ecu pinout: http://www.ozhonda.com/forum/showthr...P2K-ecu-pinout
    2. VAFC wiring: http://www.civicforums.com/forums/17...tructions.html
    3. VAFC VTEC wiring: http://honda-tech.com/showthread.php?t=1628016
    keep researching if you haven't a clue, or pay someone to do it! This goes for the engine head swap too!
    All information on P2K ECU pinouts has been provided by ECU-MAN!
    The RPM wire (Green) is important as it will signal your VAFC to activate VTEC! So be sure to wire it to Connector A pin 21 YEL/GRN or do it my way and wire it to your tachometer.
    VTEC JUST KICKED IN YO! BWWWAAAAAHHHH!!
    Attachment 20274
ID:	20278   Click image for larger version.
ID:	20279   Click image for larger version.
ID:	20280   Click image for larger version.
ID:	20282   Click image for larger version.
ID:	20284   Click image for larger version.
ID:	20286   Click image for larger version.
ID:	20287   Click image for larger version.
ID:	20288   Click image for larger version.
ID:	20290   Click image for larger version.
    Aug 2011
    Liverpool, NSW
    EK9 minus 8
    Any vids of it going hard?
    No recommendation to surface grind the head ?
    Jun 2010
    1995 Civic Ek1
    the head I bought was already machined and good to go. I'll put up a video of it. My car is still on stock fuel mapping. Need to get it properly tuned for maximum performance. But when it crosses over, I do feel some pull.
    Aug 2011
    Liverpool, NSW
    EK9 minus 8
    How good is the fuel consumption also?
    Jun 2010
    1995 Civic Ek1
    well currently it's just the same. Unless I vtec it all the time. But it's pretty good. However I may need to change the fuel mapping, but i'm pretty sure it won't be bad. d16 motors are meant to be really fuel efficient.
    May 2010
    Cabramatta,NSW
    DB6
    Vid of vtec kic plzzzzzzzz
    Jul 2011
    Glenmore Park, NSW
    99 EK1
    Great guide man. Very helpful. Been thinking about doing this for a while and this will be very helpful if I get around to it haha
    Jun 2010
    1995 Civic Ek1
    Cheers man, my friends were the big helpers in it all. I'll post a vid as soon as I can. need to find my camera mount :S need to take a vid of the vafc engaging and dashboard when it crosses over
    Jun 2010
    1995 Civic Ek1
    Finally got it done! sorry for the delay! not properly tuned yet.. don't have time atm coz of exams n shit
    Aug 2011
    Liverpool, NSW
    EK9 minus 8
    not too bad imo how big was the difference?
    Jun 2010
    1995 Civic Ek1
    Definitely feeling a big difference! Better pick up too!
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Great effort mate,sounds nice as!!
