Results 1 to 4 of 4
Thread: Car overheat?
Hybrid View
    Newcomer Array
    Sep 2008
    SID KNEE
    Car overheat?
    Hey, i drive an ek4 and it overheats really weird. I drive my car with the cold temp on and my car will over heat to the point where the needle nearly hits "H", but as soon as i pull it over to the hot side, it drops straight away back down to mid way where its at optimum temperature?? I open the bonnet when the car is "overheating" to find the thermo fan not working, and this is with out the air tuned on?? Im going to be changing my fan switch and see how it goes. But i can drive for hours like normal with the hot side on and its fine. Anyone had this problem??
    Thanks
    If uncle Jack helped you off an elephant, would you help uncle JACK OFF an elephant???
    If I'm not back in 5 minutes..............just wait longer
    yeah i got a dc4 with fan that does not work. its only moving up so quickly because your the heat is not radiating with fresh air when your idling. u can watch it rise pretty quickly when waiting for traffic or the lights. and why it drops so quickly is because u started moving again, it cools down in less than a minute once you begin moving again
    Newcomer Array
    Sep 2008
    SID KNEE
    Yeh but when its on the hot air side, its perfectly fine ?? So it has to be working?
    Aug 2007
    Sydney
    DC
    if you going to replace your fan switch also consider changing your thermostat aswell, if the fan isn't switch it could either be thermostat is not opening and letting coolant pass through or you have air pockets circulating around, I guess when you change those compontants do a bleed of the coolant and make sure there's no air pockets left.
    Coup De Grace
