Thanks,
I think I read the wrong number off the placard I think it should be btwn 220 to 240.
Can anyone with these (pizza cutter!) tyres tell me would PSI they are running them on?
Thanks,
cheers.
Yeh, thought it sounded a bit high. 220kpa = 31.9psi, 240kpa = 34.8psi
227kpa = 33psi
I checked it on the air pump machine form petrol station!!
You can only select the degree of psi, not kpa on the air pump machine, However, u can press the "kpa" button to check the number of kpa that convert from psi!
