Did you reuse the negative from the wiring loom for the headunit? i usually ground the headunit to the metal inside the dash so i know its got a good connection. may be worth trying if its not your rcas as it doesnt take long and you will have the deck out while your swapping rcas anyway
Also if your rcas arnt damaged but are causing engine whine they could be run to close to other soruces of power(this can cause engine whine) so it may just be the rcas are poorly sheilded and/or run too close to other wires.
I dont believe its the wiring from the hu or the grounding from it, as ive never had trouble till i plugged the rear speakers in, so im gonna rule that one out
Originally Posted by slimx
if u are using a pioneer head unit,
its common
u nkow what u can try and it will help i assure you.
Get a copper wire put them around the RCA's make sure they are touching EVERY female rca socket on your head unit and ground them to any screw on the back of the head unit.
cheers man, will defs try it, I am using a pioneer HU
