Results 1 to 8 of 8
    Nov 2008
    Melb East Side Yo!!
    Teggy, Spada Vt
    Angry HID Fogging issue
    ALLO!
    having a issue with my HID 6K's on my spada vt250. the lamp seems to be fogging up? any suggestions as to why?
    didnt happen for about a month after installation and now its all misty. sometimes the light seems to turn yellow and then turns white again any reason for this? is the bulb dying off?
    any suggestions to both issues are appreciated.
    Many thanks ppl.
    -=¤§ ń Ĩ ģ ĥ ţ Ŵ ő Ł F §¤=- ™
    info worth the rep point?
    WIFE AND DOG MISSING!!!
    REWARD FOR DOG
    Jul 2007
    JDMD15B
    14EGs/8EDs/3EKs
    Sounds like the ballast is playing up.
    There's only a 1%/2% rate of bulb failure when it comes to HID's.
    Try whacking another one on there to see if there's a difference.
    JDM D15B - you wouldn't understand
    No K-SWAP ? No worries - Unfriend
    Nov 2008
    Melb East Side Yo!!
    Teggy, Spada Vt
    i guess ebay is my best bet with getting a ballast... any idea about the fogging issue with the lamp?
    REWARD FOR DOG
    Jul 2007
    JDMD15B
    14EGs/8EDs/3EKs
    Are you saying your headlamp cover is fogging ? Getting misty ?
    Is it glass or plastic ?
    Nov 2008
    Melb East Side Yo!!
    Teggy, Spada Vt
    sorry for the late response....(internet issues hehe) its glass and its fogging up for no reason. it fillament is sealed so no moisture can get through but the glass fogs up. any ideas?
    REWARD FOR DOG
    Dec 2009
    Sydney
    K20 nugget
    When you say 'fogs up', do you mean moisture, or it's going yellow?
    If it's moisture, did you seal the rear of the head light housing completely after you installed the HID kit? Does the HID's rubber gasket have a nice, snug fit all round? If it's open or loose, it will allow moisture to develop. Especially if you've been riding a lot when it's cold (hot inside, cold outside). Once you turn it off the head lights will cool down quickly causing condensation.
    If it's going yellow, it could be that the HID kit is using cheap bulbs which do not filter UV rays. The UV rays from the bulbs can make head light lens turn yellow. This is only on the very cheap end of the scale or on much older kits.
    Nov 2008
    Melb East Side Yo!!
    Teggy, Spada Vt
    Quote Originally Posted by androo View Post
    Honestly its a third party brand made in china but most of em are made there so thought what the hell. its not really turned yellow but its more misty white. i ensured there was no way moisture could get through using a custom seal but theres no way i could test it.
    got a new ballast and then change in color doesnt seem to affect me anymore but just installed it yesterday so couldnt do a proper test.
    ill try and post a picture of the lamp which will provide a clear picture of my problem.
    Thanks once again for the input.
    REWARD FOR DOG
  8. #8
    yep thats the yellow, if im not wrong happens from the lamp getting cooked up? at least thats the case in my friend's bro's EM1 with HID
