Page 2 of 2 FirstFirst 12
Results 13 to 22 of 22
  1. #13
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Just curious, got any vids for us?
  2. #14
    Oct 2010
    Brisbane
    DC2, EM1
    Quote Originally Posted by dougie_504 View Post
    Or engine bay pictures? I would love to see how it looks with a supercharger in there.
  3. #15
    May 2010
    Newcastle
    Honda Integra Type R JDM
    for sure, ill get up a video once i fix the driveshaft...
    jdmEG5: Will u take 2 ounces of weed +$500 your way? I'm not kidding.
    Speed is a matter of money... How fast can you AFFORD to go?
  4. #16
    Aug 2008
    gladesville
    DA9-N/A DC2-S/C
    Quote Originally Posted by Alexplicit View Post
    Tom, if you know what the plates where on the car when he tuned it he can bring up what it has.
    Cant remember them. I handed the plates in when the revs expired. 2 years back
    touge is my style, F@CK your style!
  5. #17
    May 2010
    Newcastle
    perhaps you have a photo of the car with its old plates on it?
  6. #18
    Aug 2008
    gladesville
    DA9-N/A DC2-S/C
    Ano70k
  7. #19
    Array
    Aug 2003
    Unit 5/15 Sefton Rd, Thor
    08 Red CU2 Euro
    Ok Tom...
    Here's your Power & Torque (130.1kw)
    [/IMG]
    Here's your power vs A/F's
    You can see you're out of injector at 5500rpm
    The car left after that to have bigger injectors fitted & fuel pump + MAP sensor relocated to plenum etc but never returned to have the tune completed. (Instructions to GPC when car was sent back - I can't say if these were ever completed)
    & for you & Alex to bench race,
    Here's you vs Alex
    Alex's advantage is MAP sensor reading boost from plenum, rather than the MAP sensor on top of the throttle as is yours.
    Bigger injectors & Type R cams.
    You have a capacity advantage which can be seen as superior power & torque below 5000rpm.
    Alex's cams & compression puch ahead beyond 5500rpm (also with an advantage of correct fueling)
    Your car (Tom) also runs higher boost than Alex, but only becasue your cams are smaller & not optimised via adj cam pulleys (9psi vs 6~7psi) which tends to lower the boost shown.
    Your Vtec swap is also at 4200rpm
    Hope that helps,
    Cheers
    Adrian
    TODA Performance Australia Pty Ltd
    TODA Racing - FIGHTEX - MFactory - HALTECH - EXEDY
    Race engines, Dyno tuning, Licenced workshop, Parts.
    P:0401869524 email: toda@todaracing.com.au
  8. #20
    Aug 2008
    gladesville
    DA9-N/A DC2-S/C
    Well the items you mentioned have been fitted for some time now and will bring the car back for calibration. After I get time to fit my big tube header.
  9. #21
    Aug 2008
    gladesville
    DA9-N/A DC2-S/C
    Considering the fuel pump,440cc inj and adj-cam gear on the in-cam. What kw and Nm would I possibly get?
  10. #22
    I want to run 6-7 PSI on my B18CR
    What size pulley do i need to get if im running stock Crank pulley?
    The pulley that is currently on my S\C is very small....
