Results 1 to 9 of 9
    Nov 2005
    NSW
    ED6
    Do I Really Need to Use Honda Manual Transmission Fluid ??
    Hi guys ,
    looking at getting manual transmission fluid changed on my EK1 , but can not get genuine Honda fluid unless i wanna make a long trip to Honda dealer
    so , looking at the viscosity on genuine honda manual transmission fluid , it's 75W-80 so , i can get Penrite manual transmission oil in the same viscosity plus i'm going to use the friction modifier additive (G70 from Nulon)
    what you guys reckon ? any other inputs are welcome
    Cheers
    Sep 2008
    Melbourne
    Kermit K20A
    You will find a lot of people on here say to use Honda Genuine fluids, but they fail to realise that Honda fluids are just Castrol products slightly modified & re-labelled as Honda products. Provided you use the additive, the Penrite product will work just as well as Honda Genuine
    Kermit EGK20A
    Winton: 1:35.08
    Wakefield: 1:08.8
    Nov 2005
    NSW
    ED6
    Thanks for your input , i'm surprise that Castrol didn't do 75W-80 transmission oil tho.
    also , very hard to find the right viscosity transmission oil to suit Honda gearbox , i'm really wanna use Nulon product but Nulon recommended to put SAE80 Smooth Shift Manual gear oil (straight 80) , a bit unsure tho ?
    Sep 2008
    Melbourne
    Kermit K20A
    No harm in trying out the SAE80. I reckon you will find it will do the same job
    Kermit EGK20A
    Winton: 1:35.08
    Wakefield: 1:08.8
    Nov 2010
    inb4yursorryass
    have a read through this ..
    it has been discussed before ... im sure it can shed some light for you
    http://www.ozhonda.com/forum/showthr...ht=gearbox+oil
    B to BFrank to K .... ive had it ......
    Nov 2005
    NSW
    ED6
    Quote Originally Posted by IV73CI View Post
    Thanks for your input , will check Castrol VMX-80
    Cheers
    Nov 2010
    inb4yursorryass
    Quote Originally Posted by subie View Post
    Cheers
    np ..
    thought u were going with Honda MTO .. lol...
    all good ..watever tickles your fancy
  8. #8
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    I've used both Honda MTF and Castrol VMX80. Both work fine. Do whatever you want mate. I just use the Honda stuff because I buy parts from there regularly and just stock up while I'm at it...
  9. #9
    Quote Originally Posted by stndrd View Post
    I was under the impression that the engine oil was Mobil 1?
    Also OP, if ever in doubt, just go by manufacture recommendations, at least then you know you will be safe.
