Blackwoods carry Unbrako but any nut/bolt trade store would be able to supply them I'm sure
The specs are pretty straightforward. You need M10 bolts about 50mm long (depending on spacers and flange thickness for your application). But look at Nord-Lock washers too.
Originally Posted by EKVTIR-T Blackwoods carry Unbrako but any nut/bolt trade store would be able to supply them I'm sure cool , i'll sus it. Do you know specs? or is it going to be specific to what i've got setup in mine? cos i've got after market axles and cvs
Originally Posted by AusS2000 The specs are pretty straightforward. You need M10 bolts about 50mm long (depending on spacers and flange thickness for your application). Thanks AUS!
Oh, and the OEM bolts are normal 6 sided nuts and bolts with a serrated flared skirt. I used hex head bolts on mine though.
