what actually shakes? the entire car or your steering wheel?
things to look at;
1) What is your tyre pressure?
2) When was the last time u got a wheel alignment?
3) Did you get new tyres? if so, have you done #2?
3) When travelling speeds above 60klms, do you hear oowing noises or the sounds of wheel bearing noises?
4) Did you install anything recently? if so - did you fit all the parts correctly / secured? i.e. engine mounts etc?
5) Are your shocks on its way?
6) Are the other gears - 1-3 ok? - no vibrations?
- If vibrations or noises can be heard/felt, then your gbox could be on its way...
the above are common faults, go through it 1 by 1 and inspect --> rectify.
things to look at;
let us know how you go.
1. The steering wheel mainly but it also feels like the car.
2. Front wheels are on 33 PSI and back on 32.
3. Haven't done a wheel alignment yet as I just bought the car.
4. No noise from the wheel bearing.
5. Has coil overs but pretty sure its installed properly.
6. Gears 1 - 3 and 6 are ok.
7. Vibration can be felt not heard.
ikr - my first was a lemon - every pay day would go towards to the car in fixing the fhuker. so after having the car for 6months i sold it.
too much hassle and waste of money.
but dont give up str8 away - try the simplest and cheapest solution first then reconsider.
yeh you're right - its nto an issue as such its just a head dooer because i work 5 days a week so i have no time and mechanics are so busy on the weekends..
Most tyre shops are open till about 4pm on a saturday (in melbourne at least) so you should be able to get your wheels balanced & alignment done no worries =]
