Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: Leads...
    Jan 2005
    Melbourne
    Ventura Bus Route
    Leads...
    Hey guys, i would like to invest in some good leads. the other day i saw a set of leads on a s2000. they ended with 'OY'. i believe they where from the u.s. he said performance gains where significant. up to a 5kw gain!! i got priced on spoon ones, they where maybe a bit too much.
    your thoughts, experience?
    Sep 2003
    Pyrmont, NSW
    Red Rocket SSV
    Saturday at the Adelaide DynoDay we had a lil test to see what leads would do what with my 99 DC2-R,
    with aftermarket japanese "Super Power Five Core Leads" 9.5mm ignition leads the ITR pulled 110.4kw @wheels
    with OEM STANDARD DC2-R ignition leads, the ITR pulled 111.1kw @wheels
    now this is a DC2-R, which is renouned for its already highly fine tuned engine, so aftermarket leads may help increase power in other cars/ other engines.
    Banned Array
    Aug 2004
    Adelaide
    Gen3 CRX
    doubt it
    Jan 2005
    Melbourne
    Ventura Bus Route
    Quote Originally Posted by mr crex
    fairplay mate but, on a b16a i dont think it would be the same case. however, in the case of a power GAIN, it was tested on a s2k! im sure that has the same 'refined tuning' as a ITR
    Banned Array
    Aug 2004
    Adelaide
    Gen3 CRX
    we're telling you its a waste, its obvious you've made up your own mind already
    Green block gangster Array
    May 2004
    twin GX160's
    i think it would be the same case, OEM leads are better than alot of aftermarket leads.
    also heard a story of the same thing Mr CRX said, with a H22A1 Engine, OEM leads made more power than aftermarket leads. the test was done with old OEM leads compared to some new after market leads
    Jan 2005
    Melbourne
    Ventura Bus Route
    Quote Originally Posted by ProECU
    doubt it
    instead of using two words as a reply, at least try using the 'quote' option. it was quite easy to think you where saying 'doubt it' to mr crex...
    thanks anyway.
  8. #8
    Banned Array
    Aug 2004
    Adelaide
    Gen3 CRX
    good point
  9. #9
    Use OEM or similar leads. The only reason you would gain power would be if your current leads where buggered.
  10. #10
    Dec 2004
    Sydney
    EK1 & CL9
    ive just put in ngk oem replacements in my EK, couldnt be happier. saved myself quite a bit of $$$ from not buying original factory leads.
  11. #11
    Mar 2004
    Sydney
    Prelude Type S
    i havent seen proof that lead increase power, if so post the site up or a pic of the dyno and i will go buy myself one too
  12. #12
    Dec 2004
    Sydney
    EK1 & CL9
    i wasnt in it for the power increase, notice how i said OEM replacement? just needed new ones because mine were pretty old.
