Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 36
Thread: My DC5 Build
  1. #13
    Jul 2011
    Sydney
    DC5R
    looks like an absolute beast of a build
  2. #14
    So my buddy Phillip came down and we went to town on the bay last night. As I said we focused on filling the bigger holes.
    cleaning metal to weld up
    Testing fit
    Tac in place
    Weld
    and walla
    same thing with the old brake line holes
    but placed the metal in the back side
    The ultimate hole filled.....
    traced out our pattern
    cut it out
    start welding it in
    then started sanding it down
    Then Phillip started some filler
    also started welding and smoothing the motor mount
    Not going to work on it tonight... but I'll keep cleaning up tomorrow
  3. #15
    Ok spent another four hours in the garage today working on this bay...
    used a wire brush to clean up some of the back firewall
    and here are my main two tools for grinding
    So I cleaned up some of the new fill plugs
    before:
    after:
    before:
    after:
    (we will fill in the middle)
    and here is my bay as it sits currently
  4. #16
    So we decided that it would be better to weld everything verses weld some and mud some... so I spent the first part of the night trying to remove all the filler we had previously laid
    then cleaned so we could weld
    had a lot of troubles with the welder. I had to go get a new tank of gas an then had to go get new rod as I ran out of both... then we couldn't get the welder adjusted correctly at first so it was welding like crap. We eventually got everything smoothed out and it started welding smoother
    spent hours grinding lol
    I know it looks rough... my back was hurting
    and then welded up the other side after I cleaned out the filler
    as she sits
  5. #17
    So I spent around 5 hours today working on the damn car... man this is a lot of work... and I feel like I haven't even made a dent in it!
    so here was where I started
    pain in the ass and no where done
    started griding and didn't like how it was looking
    so I, yes I, rewelded it.
    also rewelded the bottom of this section
    and added more filler to the side
    then started focusing on the other side
    grinded down
    started the sides
    and spent a lot of time here
    hard to tell but it's looking great IMO. Some filler will clean it up alot and smooth it out great!
  6. #18
    Nov 2011
    nimbin
    DC5R, EG & EP3R
    cant wait till this is done... looks good
    BARPPP
  7. #19
    Looks fantastic dude, keep it up!
    May i ask, the purpose of re-welding, what do you achieve exactly?
    I understand the grinding it down so you can smooth it upon so you get a smooth finish but is the welding for structural integrity? or so you can achieve a 'shaved' engine bay?
    Thanks bro
  8. #20
    Quote Originally Posted by WATAJK View Post
    Thanks bro
    The welding has several purposes. One is strength. Like on the strut towers and around the motor mounts. It adds extra strength to the factory pinch weldings.
    The second purpose is to help add material so I can grind and smooth out the bay. This will also allow me to use less filler which has a tendency to crack.
  9. #21
    So I took a break from the bay today and focused on my engine. I just wanted to seperate it from the trans and get it on a stand. I will start working on it from here now
    So here is what I started with:
    Then I started pulling off the supercharger, harness and misc
    and to be safe started boxing up all my parts lying around
    Busted the engine hoist back out
    lifted her up so I could take the trans off
    then pulled the trans off
    threw it up on the stand
    and done
  10. #22
    So started pulling out my interior too....
    pull out the backs next
    poor car lol
    Here are all of my bars lol
  11. #23
    redid my FPR again today while I'm finished up welding.
    So I made a template
    cut it out
    smoothed it out
    drilled the holes
    test it out
    bolted it where I'm running it
    welded it quick
    and sanded it down
    I'll clean it up more later when I get to this side. Phillip went to town starting the driver side and I must say HOT DAMN
    it is so smooth and gonna look sick
  12. #24
    Aug 2011
    Liverpool, NSW
    EK9 minus 8
    Very nice build you got mate
