"The first symptoms of a head gasket that is failing are usually a slow loss of coolant with no visible leaks, engine overheating and/or a Check Engine light with cylinder misfire codes."
Not sure if hg is gone, but it has been losing coolant for months and i can't seem to find the bloody leak! If it's leaking, should the oil be 'chocolate milkshake'?
