The tachometer takes its signal off a sensor in the distributor - check
The wiring from the dash to the engine bay wiring loom , and then also check the dizzy clip itself . Make sure no pulls or shorts etc. might also be the sensor itself is dying/dead leaving you with the need for a new dizzy
