Page 1 of 3 123 LastLast
Results 1 to 12 of 33
    Oct 2011
    Sydney
    EG5 B18C7
    building head for more power gains B18c :D !
    hey guys , as the title states . Im looking to do some headwork for my b18c7 but am pretty stuck on what to do .
    Currently i have a stock b18c7 , only bolt-ons at the moment are Jays racing Carbon intake , Random headers (not sure what brand) and Hurricane exhaust full catback and 2inch aluminium exhaust . Im currently using hondata s200 but is untuned , hence why i also believe my car could be running rich .
    other than that , everything is pretty stock . From what i know , if i get camshafts i should also upgrade my valve springs and retainers as they get put under more stress .
    I also realised that there are different models such as spec 1 , 2 and 3 . one being moderate , 2 being street/ track and 3 being track dedicated not suitable for street .
    I want power gains , a reasonable amount but dont want anything that has too much power that could alter the functions of a daily driver . does that make sense ?
    I dont know too much about the in depth technicality of what to do , thats why i thought id ask .
    I think ill be getting stage 2 ( unsure of what brand) camshafts , upgrade valvesprings and retainers and get tuner adjustable cam gears .
    is there anything else i need to be putting into consideration ?
    Am i missing anything ?
    whats the difference between double and single vavlesprings ?
    In relation to spec 2 or stage 2 camshafts , do different brands offer different power outputs or are they all the same since they are all in the same stage ?
    i tried covering what i could so i dont get flamed for asking .
    YES i am a noob and love to learn so any input would be great . thanks guys !
    " MY VTECC GOES BWAHHHHHHHH BAHHHHHHH BWA BWA BWAAHHHHHHH "
    Oct 2009
    hehe
    hehe
    Well first off, replace all of those shitty bolt-ons with something half decent. You can't just throw cams in and expect good power gains, you have to have a good combo.
    'stages' of cams will vary from manufacturer to manufacturer, just because they are for example, both stage 2, it doesn't mean they'll necessarily have the same lift/duration.
    Yes you can have good power gains and still retain good drivability/fuel economy, just need to have your shit sorted, ie good combination of parts and a good tune.
    Oct 2011
    Sydney
    EG5 B18C7
    LOOL of course , im planning on changing the "shitty" bolt ons but after i do some headwork seeing as more power is made there . after the head ill be changing my full exhaust , headers and intake . still yet to decide on what to get though .
    ahh okay , in terms of lift and duration what do you mean ? i dont know too much about " lift/duration"
    ill be getting it tuned once i sort out what i need and what to do , but thanks for the input
    Oct 2009
    hehe
    hehe
    from google
    Duration refers to how long a valve is opened in relation to crankshaft rotation. This open valve time period is expressed in degrees of crankshaft rotation. So, a cam specification of 220 degrees duration simply means the cam holds the valve open for 220 degrees of crankshaft rotation.
    lift, how wide the valves are opened
    If you are serious why don't you talk to a good mechanic? toda au on the forums here really knows his shit about b series.
    A good (and expensive ) combo would be:
    mugen/injen intake
    toda header
    100cel metal cat
    buddyclub/fujitsubo/spoon ect catback
    toda b's with all the appropriate valvtrain upgrades to support
    cnc port job
    thinner head gasket
    if you engine is healthy, expect up to 140kw atw
    but then again thats nearly k swap money... (i was considering this before i went to k)
    inb4 adrian
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    IMO fix your bolt-ons first before you do any headwork. Lightweight flywheel and HD clutch would be a nice addition too. Head work isnt cheap!
    Jul 2011
    Australia
    S2000
    Yeah, What these guys have been saying. I'd try to do as much as I can in terms of bolt-ons before thinking about internals. They're much cheaper and easier to work with while providing noticeable gains
    Jun 2006
    WA
    EG+CL9
    Fujita > Injen for CAI
    i would fix your bolt ons and get the hondata tuned before messing with the head
    would be interesting to see what adrian has to say =)
    D15b Turbo EG Sedan Build + CL9 Lux N/A Build
    http://www.ozhonda.com/forum/showthread.php?t=127680
  8. #8
    Oct 2011
    Sydney
    EG5 B18C7
    thanks for the input guys . yeah i was thinking of doing it backwards for some odd reason . head work and fix all bolt ons .
    Most likely gonna change my Jays intake for a CAI and change my full exhaust , decent set of headers with a better exhaust .
    in terms of bolt ons , any suggestions ?
  9. #9
    Sep 2008
    Melbourne
    Kermit K20A
    CAI, 4-2-1 headers (toda, mugen, j's racing etc) with 2.25 or 2.5in cat back exhaust, 100 cel cat, bigger throttle body match ported to inlet manifold, walbro intank fuel pump & tune
    Kermit EGK20A
    Winton: 1:35.08
    Wakefield: 1:08.8
  10. #10
    Oct 2011
    Sydney
    EG5 B18C7
    Quote Originally Posted by stndrd View Post
    (Y) thanks . LOL
  11. #11
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Quote Originally Posted by joeyybruh View Post
    IMO screw internals just swap the block for a B20 lol
  12. #12
    Sep 2008
    Melbourne
    Kermit K20A
    Quote Originally Posted by dougie_504 View Post
    +1 then stick a turbo on it. Boost fixes everything
    Kermit EGK20A
    Winton: 1:35.08
    Wakefield: 1:08.8
