Can someone tell me what order these colours go in from left to right?
Wait for ECU MAN to reply. Would be good if you can give more info... Wiring isn't the same colour for every car you know ?
JDM D15B - you wouldn't understand No K-SWAP ? No worries - Unfriend
looking at the above picture the picture shows the back of the connector wire side. since colours always change between generations and models use a mulitmeter to identify your wires and connect them. http://www.ozhonda.com/forum/showthread.php?t=67230
You must spread some Reputation around before giving it to ECU-MAN again.
Originally Posted by tiksie lol Cheers mate!
Also, there should be a manifold Vacume hose that connects to the map sensor, can anyone show me where this is?
Originally Posted by vtecing Also, there should be a manifold Vacume hose that connects to the map sensor, can anyone show me where this is? Depending in your engine model / throttle body, the only hose that connects next to the map sensor is a hose from the charcoal canister. There are other vacume hoses that do plug into the intake manifold. I couldnt take a pic of my TB as ive got an aftermarket s90 tb. And hoses are deleted besides the coolant hose to the TB.
