Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 42
  1. #25
    Nov 2010
    inb4yursorryass
    Quote Originally Posted by ALLMTR996 View Post
    This engine has
    NO CNC crank work where that came from I have no idea
    Bearings are ACL Race Series
    The conrods are SCAT
    Pistons are RS Machine 84.5mm they have a 3.5cc dome based on USDM ITR pistons
    Head studs are ARP
    Cams are Rocket Motorsport M22x
    Cam gears where Skunk2 Tuner series
    CYL Head is a STD ITR
    yes Supertech flat faced valves,Springs,Titanium Retainers
    Combustion chambers where CNC machined to 81.5mm bore
    wow thanks dude...i only knew some of the actual specs..
    but yes thats what i meant ..CNC machined combustion chambers.
    but the Crank has been balanced (apparently)
    now i know the brand of the cam gears.
    Yes CYL head is std ITR it hasnt been ported etc.
    extra stuff i didnt know exactly what was done/put on.
    How do u know so much about the build?
    i know DD built it .. and its suppose to be a strong motor. yes / no?
    B to BFrank to K .... ive had it ......
  2. #26
    Dec 2009
    Sydney
    DC2R, EK4
    ALLMTR996 = Dyno Dave
  3. #27
    Sep 2005
    Somewhere In Oz
    CD5 Accord
    And your point?
    Its just good to see that engine still running we all had alot of fun with it and learnt heaps from the developments we did when I was helping the boys.
    The life of a 4 stroke engine
    It sucks it squeezes it bangs it blows
  4. #28
    Nov 2010
    inb4yursorryass
    And your point?
    my point is ..that you guys did a great job in building it ..and buying a built motor is something that i would want to know more of if its a well built strong motor
    i only knew DD (you) with his old screen name as DynoDave ...
    u dont remember me, but i was the one who bought Marlons old Lancer with the turbo honda frank in it ...(Jordans aka BAL11W - old motor)
    so strong build yes/no?
  5. #29
    Sep 2005
    Somewhere In Oz
    CD5 Accord
    Damn blast from the past.
    Yes its a very strong engine the boys really tested it and we never had any problems.
  6. #30
    Sep 2005
    Somewhere In Oz
    CD5 Accord
    Quote Originally Posted by Mr.Brightside View Post
    I was answering op's question, problem?
    No problems
  7. #31
    Jan 2010
    PnP Garage
    BREEZE
    is it just me or are things heating up in here?
    Why everyone so defensive?
    part time potato
  8. #32
    Feb 2008
    Orange county
    Pimpin rover
    Quote Originally Posted by IV73CI View Post
    tru that.
    Bottom End Build:
    CNC Machined and balanced crank
    Eagle Rods
    11.3.1 CR
    Top End Build:
    ITR head
    Supertech valves, springs, retainers
    ARP Bolts
    ITR IM matched ported
    Stage 2 Rocket Mx Cams H/L profiles
    S90 TB 70mm
    440cc Injectors
    Works Fuel Rail
    Breather kit
    Walbro fuel pump
    Gearing
    ITR LSD GB
    Exedy Lightened F/Wheel
    Exedy Stage 2 clutch
    Zorst
    Tri-Y Big Fat tubes 2.5inch collector
    2.5inch Mandrel Bend B-Pipe
    High Flow CAT
    Twin loop Muffler
    ECU
    S300 tuned on E85 V1 V2 (final tune to be done)
    thats about it just waiting on a V2 final tune as ive installed new parts and need to make use of its potential.
    not a bad list lol
  9. #33
    Sep 2005
    Somewhere In Oz
    CD5 Accord
    Quote Originally Posted by Vvvtec View Post
    All seems normal to me.
  10. #34
    Nov 2010
    inb4yursorryass
    ^^ x2 all normal in here ...
    just clarifiying some very helpful info ..
    and DD - yes blast from the past i tellz ya..
    good to hear your still in your game/cars
  11. #35
    Sep 2005
    Somewhere In Oz
    CD5 Accord
    Your engine also had a Circuit Worx cromemoly oil pump gear as well.
  12. #36
    Nov 2010
    inb4yursorryass
    Nice.. So alot of hard workmanship, quality parts, and hours has been put into this build.
    Do u knw if its a requiremet to get a blockguard or sleeve it?
    Could i run a turbo kit @ 17psi with the current engine build?? Or the sleeves not strong enuf and the CR is too high?
