Well..if they pull you over and you feel that you have a valid argument...just print this out and show them...(found it for yas)
http://www.tmr.qld.gov.au/Licensing/...-P-plates.aspx
How the plate must be fitted
A P-plate must be fitted:
to the front and rear of the car (rear only for motorbikes)
so the 'P' character is visible on each plate from 20 metres (m) away at any point within an arc of 45 degrees from the surface of each 'P' plate above or to either side of the car or motorbike.
You're welcome =P
