Hello guys!
I just done DC2 5 stun convertion on my ek4!
I'm confusing what is the right alignment setting.
I'm using for 90% street 10% track.
All suggestions are wellcome!
I would suggest Toe settings at +0.5 front and rear (toe in) for stability - maybe up to +1.0 on the front if your caster bushes are completely stuffed.
If camber is adjustable (hardrace arms or the like) i would go 1deg neg front and around 0.5 neg rear.
This all depends on your ride height and tyre clearance - also if you have a pretty twisty route to work you can be a little more aggressive on camber since the above is fairly tame for daily driving with relatively positive feedback.
