Results 1 to 5 of 5
Hybrid View
    HELP! =[ Injen CAI install into an EK civic
    I am a total noob at this but bought an injen CAI off another ozhonda member =] The intake came off an EM1 and i assume it was a B16A2 engine? I want to put the injen onto a D16y4.
    My questions are:
    - will they fit (with/without modification)
    - will i need to buy an aftermarket oxygen sensor cable
    - what are the two holes near the throttle body for? I know one is an oxygen sensor hole but the other one.. not sure.
    ANY HELP WILL BE APPRECIATED. Thanks so much!
    Wont 100% fit - your d16y4 has a smaller throttle body than the b16a2 and the silicon end pipe MAY not fit on properly. You will have to over tighten the clamp/s so just trial fit and see how u go.
    Apart from this small issue the intake should fit exactly the same into the front right guard. You will need to remove your resonator.
    The two holes are this -
    PCV intake ( rubber tube to the cam cover) and the IAT sensor ( intake air temp sensor)
    THANKS SO MUCH! perfect answer. +1 if i could
    Ozhonda Trader Array
    Aug 2003
    Sydney.
    EGK24A
    You need to run silicone hose reducer from intake pipe to the throttle body
    JDMyard Pty Ltd
    www.JDMyard.com
    Nov 2010
    inb4yursorryass
    Quote Originally Posted by EG5 View Post
    ^^^What he said..
