Use a normal phillips head screw with washer and once tight drill the + out and when and if you ever need to remove cut the screw head off.
Simple and effective
I second this as the best and simplest idea. Only proviso is that you use low dome screws rather than the OEM ones 'cause you can grip the sides of those with vise grips (have had to do this on ones where the + is stuffed.
