EK Civic Knocking Noise HELP!
Hi Everyone,
Looking for some help, as shops can't hear it.
There is a knocking noise coming from the front of the car.
Typically going over small sharp bumps when turning and happens more often when the left wheel goes over the bumps.
All my bushes have been changed and the noise was present before they were changed.
I can feel the knock when i rest my foot on the foot rest.
Any ideas? loose steering rack???
Thanks
Green and Gold Ghetto EK4
OEM Front Lip, Ghetto Special CAI, ASR Brace, ITR Rear Sway, N+ Coilovers, X-Force Headers and TL Muffler, Custom B Pipe, type-r rear lip, OEM visors
could be a driveshaft on the way out
d16y4>>k24a3 for the win !!!!
Swaybar links or d-bushes, ball joints, steering rack (rare) - many things can cause a knock...
if it wasnt there when the bushes were changed, and started as soon as they were done, could be something not tightened up properly.
Sounds like it could also be CV joint.
Did you get the work done by a mechanic? Do you have any idea what you should be looking for when you stick your head under teh car?
if you answered yes, followed by no, dont bother asking us, just take it back to the mechanic.
to see all of my build, checkout
EDIT: as others have said ...... see the below also..
couple things to think about ;
1) Condition of the Shocks/coilovers?
2) Do you have a adjustable top pillow ball mount?
3) adjustable front camber arms?
4) damaged wheel bearings?
5) buckled wheel.
6) front RSB D mounts loose?
7) End links goneskies?
8) worse case - steering rack assembly
sus them out one by one before you start buying / replacing parts.
FK - as soon as i submit 2 more posts beat me to it.. LOL
B to BFrank to K .... ive had it ......
check your wheel nuts, this happened to me...
OVERRATED TO BE UNDERRATED
LOLNOPE!
do u do alot or burnouts rollbacks or anything ? ...
Mine had the same problem, than the wheel bearing went busted, after changing bearings, its still there, so im clueless as well atm :/
Hi everyone,
Shocks are brand new, i have replaced all the bushes that are included in the hardrace kit from JDMyard, was done by a mechanic.
Wheel bearings have been replaced.
However, the noise was there before all this work was done and whenever i bring in into a shop i ask them to see if they can hear it and they always say no. The noise has been around for atleast a year now. All work has been carried out essentially over the last six months.
Umm a CV boot did split a little while ago but the minute that happened the car went to the shop.
I'm thinking maybe its a driveshaft, the car has 247K on it and it would make sense that if is knocking around i would feel it in the foot pedal as the gearbox is right underneath.
Can someone tell me if there is anything i can look for to see if it is worn?
Also, what happens if or when it does let go?
Thank for all your help
Originally Posted by dorikin
Left engine mount
second this.. they wear out on EKs and had a similar problem
hmmm, that had crossed my mind. Anyway to check it?
