i got this problem, refer to picture: im guessing not enough camber?
So i heard you like mudkipz
I would say toe out - if there was not enough camber it should be pilling the rubber towards the inside, not out. What does the inside of the tyre look like?
OHSC
havent checked the inside yet, will do that later Edit, just checked, inside is perfectly fine
Hmm, its a bit funny that there is no wear at all on the inside... I would still suggest that your car is running toe out, but you should get it checked and aligned straight away
Originally Posted by p0c1 I got the same Humm / Whooring noise coming from the front left tyre as well.. anyone got solutions? Checked on the dealer, and they mentioned it something to do with the tyres... I'm just a bit paranoia if it's something to do the wheel barrings... (still under warranty) any suggestions? I had a similar noise most prominent at 60km/h. Like a drumming noise develop. Had wheel bearing replaced today and all quiet!
