All good man =) I should've elaborated in the first place, my bad XD
Had them on my EG, before had Koni Yellows & KG/MM Springs... The Koni Yellows & KG/MM walk all over them in any road condition. I wanted to give them a try, friend offered them for a crazy price unused and several OH members found them alright. I should've kept my old setup.
D2 no matter how anal I tried to adjust the dampers [I think it was Compression & Rebound were adjustable by a single knob? Or just Rebound can't remember] it was either floating/bouncing/rocking on softer settings or idiotic stiff on harder settings. I can take harsh but that was so bad, got rid of them after a few weeks and went onto Bilstein Shocks [Custom Spec'd] & Swift Springs, god they were nice. Yes they're not that free in height adjustment but honestly good selection of springs and shocks with the perches/circlip you won't need a threaded body to freely adjust your height. As for damper adjustment, unless they're quality products, you won't feel much difference say for a 30 step/click damper [1-8 9-17 18-26 27-30]. From memory my Koni's had 4 step? And my Bilstein iirc 5 step?, between every step you can feel a big difference and you'll find something just right for you.
Trust me, when you ride in the D2 equipped car then step out in jump into the Bilstein shock n springs like Xplodin's got. You will 95% of the time find the Bilstein/Eibach setup in this case will feel 'softer', rides better but handling will be even better because it doesn't scare you when you push, you maintain control over irregular surfaces etc. You don't need stiff spring rates to handle, just need the right ones with the right supporting parts
Use swaybars along with PU bushing to control and minimise body roll and increase the amount of communication through your steering wheel and your butt on the seat. Using hella stiff springs to 'increase' your handling is silly, all it does is makes the car more twitchy and harsh not to mention gives the shocks a hell of a workout to dampen it.
