true about the engine certificate, the engine mounts are the same as B16a-b18c-b18b mounts so provided you do a lil search can be had for as little as $150 for them
the wiring is no different to a B18c swap, using EG5 loom, will need to use a OBD1 gsi ecu if you dont want any CEL when it looks for the vtec..
I also recently helped out a mate with his car cause he wanted to rego his B18C swap in carby eg. having an increase in capacity for a 1.3L eg to installing a B18C is allowed
as it goes on the largest engine coming out for that model of car, so 1.6L is the largest engine so the B18C can be done with no engineering no hassles.
So instead of a B20B8, the op might be better off with a B18A/B engine. certainly will give a B16 swap a run for its money provided you mate it to a good gearbox.
