Results 1 to 4 of 4
    Aug 2009
    Perth WA
    DC5R
    Integra DC5 hot start problem...
    Hi guys,
    My DC5 seems to have a hot start problem. When the vehicle is starting from cold it starts first time, everytime, but when up to normal operating temperature, and then switched off for say 10-15 minutes. Then restarted, it won't fire up, unless my foot is flat out on the accelerator pedal. Only then will it chugs into life. I've carried out a quick OBD 2 testing and it looks to be fine... The only thing that looks abit iffy is the Air intake temp sensor, possibly 10C+ ambient temperature, could this be making it too lean to start when hot???
    Has anyone else suffered from a similar thing? would you please enlighten me?
    Cheers,
ID:	21651Click image for larger version.
ID:	21650Click image for larger version.
ID:	21652Click image for larger version.
    Sep 2007
    DC2 Squared
    I'm going to take a stab and say your TPS needs adjusting, ~750rpm or so, 8% TP doesn't quite sound right.
    Apr 2012
    WST SYD
    GOLDWING FTW
    ive had the same problem with a dc5
    was the INTANK FPR not holding pressure causing vapour lock in the rail whist hot and stationary
    a quick check_ while the car is at idle and hot unplug the fuel pump and let the engine starve for fuel until it dies switch the IG off leave it for 10 to 15
    the plug the fuel pump back in turn the ig on and off a few times to prime the system then try to start if it starts and that process fixes the issue change the regulator
    View Tag Cloud
    Aug 2009
    Perth WA
    DC5R
    dc5
    Quote Originally Posted by SU-WOOP View Post
    Cheers mate,
    Sorry for the late response, I've been on holiday... Yeah i did exactly as you said on 2 separate occasions and it seems too work.
    Many thanks
