Results 1 to 10 of 10
    Nov 2007
    Westside
    S2000
    B16a2 rough idle
    I got a b16a2 and when engine is warm it idles between 1000rpm and 1500 rpm for like 3 times then it stops. I have looked into the bay previous owner had an intake but didn't put the air sensor back ? Not sure what it's called the one that plugs into the intake arm. Now I just want to know 100% that's the problem before I go and buy it
    Apr 2011
    syd
    Civic EK/EP3R
    it's pretty much the exact same. yes.
    lol u mad? get fkd m8
    no more mr nice guy, now i am kunt
    Jan 2011
    Dunhill
    Winfield
    em1 and sedan straight bolt on
    hatch is shorter by a bit so need to modify if using hatchj
    Aug 2006
    in your vagina
    SEX 24/7
    YES it will fit.
    srs
    EGK20A - CIVIC Sleeper stylez
    0405603619
    yeah it did mate, my brother did it
    Nov 2007
    Westside
    S2000
    Thanks guys
    Nov 2007
    Westside
    S2000
    Bump new question
  8. #8
    Nov 2010
    Some where in the world
    b18c2+T Ej8
    If the sensor (IAT)is not pluged to the intake you will get engine check light. Get the sensor anyway and put it back if the problem still exist, you will have to clean iacv
  9. #9
    Nov 2009
    The Guy Next Door, Lol.
    KSWAPPED STi -R
    Theres a diy on this issue. Search for it lad. Remember reading it when I had this problem.
  10. #10
    Intake Air Temperature (IAT) sensor. Put it back in you need it.
