Page 1 of 4 1234 LastLast
Results 1 to 12 of 38
    Apr 2008
    west
    DC2 VTI-R
    ENGINE IS OUT! What should I install while it is?
    Hey guys,
    What are the best things to do to a b18c7 while the engine is out of the car? Doing an engine swap for an em1! Was thinking of cams, but anything else worth installing while the engine is out?
    Any help and recommendations appeciated!
    Hieu
    Oct 2006
    P1.5 460F/350R
    replace timing belt, aux belts, clutch/flywheel, oil main seal
    all service items are easier when engine is out
    Dec 2008
    835 Beaufort St
    hondie 2000
    agree with above,
    you'll spend far less hours, hav less scraped knuckles and won't end up swear and cursing as much by doing it with the engine out
    hehe.
    PHC
    Apr 2008
    west
    DC2 VTI-R
    thanks guys! much appreciated, will carry out servicing!
    any further recommendations welcome!
    Aug 2005
    Melbourne - Westside M*th
    96 Integra
    degrease your engine bay with a brush and high pressure hose as well. alot easier to clean with the engine out.
    Need to do this too. What are all the main seals, service items I should replace while engine is out
    Oct 2006
    P1.5 460F/350R
    Quote Originally Posted by dorikin View Post
    main seal is behind flywheel
    Dec 2008
    835 Beaufort St
    hondie 2000
    check piston rings as well lol, junk/rebuid engine if they're bad
    hehe.
    PHC
    Ninja turtle Array
    Chloe
    Replace fuel filter and also check engine mounts and suspension bushings for degradation/wear, replace as necessary.
    Stocky CL9 - 1:17.2
    nah i know what the main seal is.. I meant what are the main items on the engine I should replace (like a full list of the common seals that need replacing)
    Oct 2006
    Hunter Valley NSW
    lownslowsedan
    Front main
    Rear main
    Cam seals
    Sump gasket
    Valve cover gasket
    Distributor o ring
    Water pump
    Timing belt
    Radiator and heater hoses
    Driveshaft seals
    Ancillary belts
    Idler pulley
    Jan 2010
    PnP Garage
    BREEZE
    Good info here guys
    part time potato
