Gday guys, little bit new here, looking for some advice re: changing gear knob on my '00 teg.
Stock gear knob screws onto a threaded shaft.
New momo gear knob
designed to slide onto a smooth shaft and is then secured by screws...i guess.
Is it possible to get this second type (that just slips onto the shaft) to fit properly onto a threaded shaft?
It comes with a few different caps for the shaft so you can get the gear knob to fit any diameter, can I just put the appropriate one onto the shaft and go from there?? Or will that not work...bit of a noob Q I know...
Planning on changing the shift boot and knob this arvo, shouldn't be to hard, just worried Ill have to try and find a knob that screws on
FYI already had a search of the forum and cant find anything that helps, hope I havnt missed a thread...
Any advice is very much appreciated!!
Cheers!
