Page 1 of 3 123 LastLast
Results 1 to 12 of 34
Thread: K20a engine
    Newcomer Array
    Dec 2010
    guildford sydney
    type r
    K20a engine
    i have a 2002 dc5 typer and my engine died. so i need to buy a new one. i was just wondering are all k20a engines jap spec?? obviously the type r here in sydney come with a k20a2 engine. would a k20a engine fit in my car without changing gear box etc... and does anybody kno where i can buy a good engine from
    Aug 2011
    Sydney
    Honda S15
    How did your engine die? Are you able to rebuild?
    K20A is the JDM engine.
    K20A2 is the AUDM and many other market versions e.g Also USDM
    So if it is a K20A it would be a straight fit. You will need an aftermarket or the JDM ecu too though. Then you'll need your immobiliser re-sync.
    IMO JDM K20A is over-priced and the only real benefit I see out of it is hard-parking credibility.
    Build a K20a and K20a2 with same aftermaket parts e.g camshafts etc. Power output will be similar if not minimally different.
    Waste of money, if your after power. Go K24 block with K20a head.
    Choke dealer
    Newcomer Array
    Dec 2010
    guildford sydney
    type r
    even if i did go with k24 block and k20a head will wouldnt i still have to tune it ?
    Dec 2008
    835 Beaufort St
    hondie 2000
    yes... but he's saying that if you're building for power it's a waste of time to spend all that time tuning a JDM engine when you can have a frankenstein instead
    S P A M | W O R K S
    hehe.
    PHC
    Newcomer Array
    Dec 2010
    guildford sydney
    type r
    ye i think ill just go buy a k20a2 but fuk there $4500 everywhere!
    Aug 2011
    Sydney
    Honda S15
    Quote Originally Posted by ellie123 View Post
    Can your head be salvaged? You can use a K20A3 bottom end from a base model to a K20A2 head. Another option. K20A3's wont demand such a steep price.
    http://www.ephatch.com/forum/showthr...ock-k20a2-head
    http://forums.clubrsx.com/showthread.php?t=789181
    http://www.google.com.au/search?hl=e....0.hQZdSt_zxs0
    Quote Originally Posted by curtis265 View Post
    Thanks alot mate!.
    OP seems to just want to get it back on the road
    Choke dealer
    Newcomer Array
    Dec 2010
    guildford sydney
    type r
    if i went with wat ur saying would this give me the same kws as a full k20a2
  8. #8
    Aug 2011
    Sydney
    Honda S15
    Dont see why not. Maybe if not same wont be too far off. Displacement is still 2.0 with the all-important hi flowing K20A2 head. [Provided that is still in good order]
    Read the threads. There are alot of myths regarding this that will be dispelled e.g unreliabiltiy at high revs, blowing the engine, turns out the guy who did this didnt put any coolant in hence the catastrophic failure. If you want to go down this route.
    I dont see a K20A3 engine costing anymore than $1500 and thats on the expensive side.
    with the cash you save you can do mods and be even faster than a stock K20A2
    Read the threads I got for you.
    K20/24 - Expensive, but highest yield of power
    Straight K24 - Relatively cheap. I'm running one. Pretty good.
    K20A2 - $4500 out of pocket and you are right where you started
    K20A2/A3 - Cheapest option, to get it running. Cant say if it will be fast or slow never done one or seen it. yanks with Ep3's do it all the time.
    Choke dealer
  9. #9
    Jan 2008
    Sydney
    legtec @2psi
    K20A3 Block has weak rods, lower compression ratio , no oil jets, no stock oil cooler, weaker crankshaft..
    If you want a weaker, lower output motor go for it.
    This would be exellent excuse for a K20/K24 build
  10. #10
    Aug 2011
    Sydney
    Honda S15
    Quote Originally Posted by GSi_PSi View Post
    ^ There you go. I didnt know that. Weaker rods, lower comp pistons and crank. oil squirters look like the primary difference.
    Choke dealer
  11. #11
    Apr 2006
    Melbourne
    Clio RS197
    K24 and k-pro for less effort. You can pick up a low k's K24 for less then $2k now days.
  12. #12
    Newcomer Array
    Dec 2010
    guildford sydney
    type r
    so wat else would i have to do if i went with k24block and k20a2 head ??
