Use the EG engine harness. But some of the plugs will be different depending on what year D16Y4 you have.
From memory the plugs are different on Distributor, injectors, alternator and the IAT sensor plug is in a different location
You can either convert your motor to OBD1 by swapping the above over from your D15B7 or change over the connectors to suit.
