Page 1 of 2 12 LastLast
Results 1 to 12 of 18
    Dec 2010
    southside
    honda civic eg
    eg rear disc conversion
    hey guys so i'm looking at doing a rear disc brake conversion for my eg civic (on drums) found a setup with handbrake lines bolts etc etc. what else do i need for the conversion? i heard just a prop valve and maybe different lines? if i go with the conversion do i need to change the lines that go to my brake booster? i recently changed the booster/cylinder to a eg8 sedan one (lines didn't fit flush.. but did some diy to fix that problem for the time being) .. anyways so what else do i need guys? and how hard of a job is it ? thankss !
    world of sikaflex (:
    May 2010
    S.E Melb
    EG5 & SF5
    stuff you need
    example for brake conversion: from eg to dc
    40/40 prop out of a dc2r
    dc2r brake master
    dc2r front knuckle,rotor and caliper
    dc2r rear trailing arm, rotor and caliper
    with handbrake cable
    dc2r rims and wheels
    remove and fit straight sway over
    -=[BLACK Dc2]=-
    EXE TRACK DAY 2014 PB 1:37.0
    he's asking about EG rear disc converson, why are you giving him a list of DC2R parts lol
    if you can get everything from a wreck/donor car it would be easier, saves time searching for everything separately. best to go looking at dc2 vtir wrecks cause dc2 and eg are pretty much the same chassis, albeit the length.
    you'd need
    - rear disc setup with trailing arms
    - handbrake lines
    - prop valve
    - bmc & booster (just incase you wanna go with 262mm front conversion as well)
    and that should be it not 100% sure what else is needed. How hard of a job it is, basically, how you remove your old eg setup is how you'll be putting on the new setup, shouldnt be any differences (cept the drums and discs, lol). Dont forget to bleed all 4 brakes afterwards!
    team.gradeA
    more smart. more safe. moreTEIN
    If you already have a 13/16" BMC and 3040 prop valve you don't have to change them when doing a rear disc conversion.
    They're factory equipped on EG5's aswell.
    May 2010
    S.E Melb
    EG5 & SF5
    Quote Originally Posted by dorikin View Post
    its an example of what is needed for conversion lols
    -=[BLACK Dc2]=-
    Dec 2010
    southside
    honda civic eg
    sweet thanks guys. well yeah i'm running 262 mm? dc2? front brakes i think its 262 but its off a dc2 . and yeah the brake setup i want to get comes with everything that would usually be in a setup calipers, hub etc etc and handbrake cables . yeah everyones been telling me its pretty simple just need a 40/40 prop valve or something..? might take a look for a new brake master as well while i'm at it . thanks for the help guys (:
  8. #8
    Dec 2010
    southside
    honda civic eg
    http://cgi.ebay.com.au/ws/eBayISAPI....:X:RTQ:AU:1123
    if i get that what else would i be needing? sorry im a nooblet haha
  9. #9
    Mar 2008
    SYD-SG-JPN-MY
    thats everything u need
    if i were u id get new rotors and pads too .
    and, their asking too much.
  10. #10
    Feb 2009
    kings langly
    jdm b16a civic
    the rear control arms are the eyelid type yea? would need diff suspension if so
  11. #11
    Dec 2010
    southside
    honda civic eg
    Oh yeah I got dc2r eyelet cuscos so it's all good . But um don't I need
    Prop valve ? And new lines ?
  12. #12
    Oct 2006
    Melb
    P1.5 460F/350R
    Quote Originally Posted by x3cindymichael View Post
    yeah you need prop valve
    it made a difference in braking.
    i had 242 front, upgraded to 262 fronts without 4040 prop valve (was still using drum pv)
    works but bit hard to brake, hard to explain but it didnt brake as hard as it was on 242.
    after pv upgrade to 4040, it was whole lot better.
    S P A M | W O R K S
