Results 1 to 12 of 16
    [CU2] Accord Lux Navi 2012 Cornering Lamp
    Anybody know what type of Bulb does the automatic corner lamp uses? (The one which switches on when you turn corners).
    Mar 2009
    melbourne
    cu2typesmodulo
    it uses the H8 bulb
    Have some 5000K Osram 66240CBI. Want some matching ones which are brighter than the standard ones with about the same color temperature, any recommendations what would be good?
    I am guessing I am restricted to using Halogens, as i'm pretty sure there is no ballast hooked up to that light.
    Max Wattage? I'm guessing 35W.
    Mar 2009
    melbourne
    cu2typesmodulo
    i am using the philips diamond vision ones in the lux nav 2012 headlights in installed on my 09 cu2.
    it sort of depends on what u are using for your hid d2s bulbs whether it is 4300k or 6000k or something else.
    easier to get the bulbs from the same brand as you know they will turn out pretty much the same.
    Ah ok. the CBI's are 5000K. How many Watts is the factory ones?
    Mar 2009
    melbourne
    cu2typesmodulo
    the factory ones are 4300k 35w d2s bulbs
    i got 6000k 55w d2s morimoto bulbs / 5700k philips t10 led parkers and 5000k philips diamond vision h8 cornering bulbs...
    they match up very nicely....the t10 parker led bulbs are something they have a very nice appearance..
    http://www.ebay.com.au/itm/PHILIPS-U...ht_1796wt_1396
    Haha, hopefully this will look good:
    5000K 35W d2s Osram / 6700 Philips T10 LED, 5000K Philips Diamond Vision H8......
    Gonna pick up the T10 and H8's tonight......
    Mar 2009
    melbourne
    cu2typesmodulo
    Maybe the 6000k t10 bulb as it might be closer to 5000k bulb u will.be using
    Ah ok, I will pick up one of those instead....
    Mar 2009
    melbourne
    cu2typesmodulo
    Here is a pic i happen to take last nite after applying the yellow tint to my fogs
ID:	22207   Click image for larger version.
ID:	22205   Click image for larger version.
    Accessing the parking/hid and side lights is through the bottom near the wheels right?
    Damn those fogs are bright, are they HID + yellow tint?
    Just noticed though, diamond vision isn't approved for road use (not ECE Approved), will it be an issue with insurance? It isn't used as the head lights, just a auxiliary side light (which not all cars have!).
    I know some people on the web have had trouble with their insurance agency with non ECE Approved Headlights, since the other company (one at fault) claimed that the other (victim) one had bad lights which caused the accident.
