Drivers side window - How to tell if the motor needs replacing
Hey guys, the window on my prelude has stopped going up and down on the drivers side, I've pulled everything apart and tried to suss it out and fix it but to no avail, when pressing the button the motor makes a noise as if its working but it doesn't..
Do I need a replacement motor/ regulator? Would the teeth be worn down on the motor coz I'm pretty sure they are like plastic on metal, ghey design fault..
Thanks for your help!
Originally Posted by Bludger
I reckon there should be a right lane, a middle lane, a left lane and a Nikki lane.....
Originally Posted by trism
look at its headlights.
if its pupils have gone massive, you know its pinging
>_<"
Is it just one side that's not working? it might just need a switch replacement.
happend to my civic.
if it doesnt go up and down ...check the below first
1) Check for any blown fuses.
2) Swap/replace window switches - test.
3) Power test the window regulator/motor
if you dont hear or feel the motor when powered up and doesnt move at all on the rotor/teeth then its had its life - replace it.
Yea just the one side :/
Fueses are all good, window switches are in working order, they turn the motor on and off you can hear it, but it just keeps winding winding winding and not moving up and down
I'm going wreckers today hopefully they can help me out with the part I need!
>_<"
100% certain the teeth on the rotor or mechanical frames are goneskies.
When u go to the wrecker ask for the complete window regulator/motor with the sliders/frame etc.
make sure that you clean & grease/lube the rollers, teeth - basically anything that slides before u install it.
Same thing happened to mine, I had an issue with the regulator/motor and ended up getting a cheap replacement from the wreckers, definetly worth getting
the the sliders/frames as IV73CI has said above.
If you need help sourcing parts just let me know as I have a friend who works at a wreckers in Kirrawee.
Make sure u get the wreckers to test to make sure the motor works like a charm b4 buying..
Hey guys sorry I didnt reply, thought I'd follow up with the situation!
Correct!
Thanks for that! Where is this wreckers in Kirrawee I called a place there and they said they don't do hondas :/
^^^ ps lol i asked them before i left and they said yea yea it works.. took it down to hanny's and they helpd me install it put it all together and didnt work hahaah, had to go back down there and they gave me one fresh off a wrecked car, installed it and all good and working, its so fast now i raced the passenger window and it beats it by a mile hahaah
I appreciate all your inputs, thanks for you help
Ps I ended up getting this from Hontoys for $120! everywhere else would not budge less than $150 to $200
>_<"
thanks for the update mate. did you get it working?
yea its perfect! so fast hahah
>_<"
