For some reason the engine on my ek1 civic was shaking as i was flushing the coolant... and also it shakes even more when i turn the air conditioner on hot. would anyone know the cause? and if this is normal?
The shaking only started happening after i had flushed the coolant, the engine was shaking so much that it could be felt while sitting in the car. The brake, power steering fluids were also rapidly moving back and forth.
After i replaced the coolent with the new, it happened again. I then took it for a drive around the block (around 7mins) and the shaking stopped and the car is fine. I think the possible cause was that the coolant didn't circulate properly or the timming belt was out of place as the car was on a jack (one side only)
Even though the car is fine now, just wanted to know your thoughts on it.
