a solution that will answer your question as to whether its worn and burning oil or not:
go to a shop that has a leakdown tester and have a leakdown test done.
then you should get your answer. you'll pretty much just get guess after guess on forums until you either do some testing or get someone else to do some testing.
-ZAMMIN-
Exactly. Until you actually take it somewhere and test it, it's purely speculation, and you're going to have tons of different views.
Yup - diagnosing via internet is guesswork and is like checking the net for a medical diagnosis - the only real answer is going to be from the guy that slips on the rubber glove and does some probing.
So i made some phone calls in my local area and sadly not one could do a compression test....
But i've had some input on several occassions that it most likely is the valve stem seal, due to the fact that "it only smokes on start and doesnt smoke when the engine has warmed up"
Pressure test. Get one done at a radiator joint. They can also do a litmus test on your coolant to see if it has carbon emissions in it which aren't always visible to the eye.
Compression test should be manageable at any shop lol.
Youd like to think that.. but the asians around here are hopeless... damn springvale, i asked if they could do it and they didnt have a clue LOL. Not sure where else to look, pretty hopeless with this shit
make sure you get a leakdown test, a compression test is no replacement for a leakdown. compression test will give you an idea as to whether its sealing reasonably ok, but the leakdown will actually tell you how much is getting out and where.
normally the symptoms for bad valve seals will be smoke at high RPM and under load, does not completely go away when warmed up. valve guides is another culprit in B series but don't jump to conclusions until you can prove what's causing it.
-ZAMMIN-
